Well I have two installed in MtX75's for duratecs. They are out there in the used market, you used to be able to buy them at the Ford parts counter. I have the cougar one still. I will sell it to you cheap, if you were certain you could make it work. We were unable to.
It is doable, you need the input and output shafts from an early 2 piece ztec mtx75. Install those in your Dtec case. Set up bearing preloads and enjoy. My 2 piece 4.06 is for sale $150 plus shipping
I'm confused about the Cougar R&P.
So, you couldn't make it work and wanted to sell it cheap.
Then say it's now possible to make it work with the early 2pc in/out shafts. Have you done it? Or is this theory?
You say you have two installed in "MtX75's for duratecs". Are these Cougar gears or are they the correct discontinued gears for dtec?
We have built two 4.06 final drive mtx75 using the later style one piece pinion gear and shaft. We have also built 4 or 5 4.75 mfactory final drive transmissions. Yes you can take the guts out of a 2000 or early 2001 mtx75 and install them in a dtec case. We had these trannys apart and back together numerous times.
Thanks a lot for the pictures. That won't work in my application either. My gear and shaft (from a 2003 Focus ZX3, 2L ZETEC, MTX-75) are one piece. I wonder what the deal is?
Thank you anyway.
John W.
To all my fellow Saleen Focus's- we should start a Saleen Crew- N2O or not- what do you think? There might not be alot of us- but thats why we are special! I am Saleen Crew# 1- the next Saleen focus to post is Saleen Crew # 2 and so on and so on- then post in your signature " Saleen Crew# _____...
Okay here it is... My 2007 ford focus 2.0 has broken the drive belt idler pulley bolt again.. First / original bolt broke at 50k. Sheared off at the block... I replaced the pulley and tensioner as well just incase that is what caused the bolt to break... 2-4k miles later it broke again..talked...
Long time lurker, first actual post. I've had my 07 ST for about 4 years now. It's done me well but a few of the common issues with the 2.3 are piling up and instead of fixing it I will be upgrading to the 2.5. My intake sounds like worn out sewing machine and the thermostat keeps throwing the...
I have a 2007 ford focus ses hatchback 5 spd with 2.0 it has a lot of options
I got it for next to nothing 2 years ago 111,000 miles..
SO I was coming home from work, and of course I got behind 2 cars side by side at 34 in a 40 with NO ONE in front of them for a mile. So when the dodge truck...
Okay so as some of you may know I've been working on my 05 Ford Focus zx4 and I was installing a stage one clutch kit with a single Mass flywheel. No I took me awhile to get to the install and a bit of time to even manage to get it in, seeing how the throwout bearing I got who with the kids...
