So the title says it all. Recently purchased a set of Hella Dynabeams, Halogen lights. The passenger light is damaged and will need a new housing, tabs are broken and part of housing on the bottom is broke off.
So I will be buying some Focus SVT HID mach headlights from DEPO and people say that it is a direct swap. So can I take everything from the inside of the Dynabeam and swap it into the DEPO mach? If that makes sense.
If so, would I have to bake it open or does it all come out the back and then the new one clicks right in? Probably not that easy....
I can't just change the bulbs because the Mach has a different shroud and no LED bar down the side.
Thanks!
Thanks!
