1 - 19 of 19 Posts
Ok, I have a 2000 4-D sedan, Zetec with the 4f27e trans.
Is it possible to swap in a 4f27e from a 2008-11 focus?
If it’s possible to do, will there be any wiring/plug mating issues?
Will the 2000’s computer talk just the same to the 2008-11 trans?
_
The later trans hooks up to duratec motor, the trans case is different from the zetec, will not fit.
Crap.
Ok, is it possible to swap the Zetec bell-housing over to the Duratec’s main case since they’re both 4F27E Transmissions?
Or will it involve more parts swapping than just bell-housing’s
It’d be good if any folk know if this is possible.
Don’t like the idea of spending the day of pulling a Zetec 4F27E & a Duratec 4F27E then disassembling them to see what part’s interchange.
Maybe, if I had a garage & couple friends to do this with.
But it just be a tedious task by oneself.
Super Moderator
id recommend an engine hoist and pulling the whole thing out of the car. I can tell you the shift plate things and trans mount (not the rubber deal the three bolt piece that goes into the rubber one) are interchangeable.
source: im using the 08-11 trans shift plate, 08-11 shifter cables and 08-11 shifter on my car currently. '00 SE Zetec.
I can look at the trans outside of my car tomorrow and let you know if the bellhousing on your '00 is removable. the rest is up to you tho...
i'd venture to say that the odds of it working are probably higher than the odds of it not working, the choice of experimenting is up to you
Discussion Starter #9
1. What is the “shift plate”?
2. Is the shift selector the same in a 08’-11’ focus, as it is for the 00’-07’?
Discussion Starter #10
Aside from the differential & final drive gears. ( to which I’m leaving alone.)
I’m wondering what tools I’ll need to do a general overhaul/rebuild of the trans.
I have the rebuild manual. But I also want to get the needed tools to do this transmission job. & maybe others at later times.
After poring through the trans manual, it’d be possible to trade bellhousing’s.
But amounts to roughly the same work a simplified rebuild would. So I’d rather do a rebuild.
Super Moderator
I don't know its actual name, but the selector on the trans side. if you use an 08-11 one you'll need the corresponding cables, cable mount, and shifter in the cabin of the vehicle. (basically everything from that plate/plate assembly to your hand)
can't answer this for you, glad you seem to have it figured out
Discussion Starter #12
slow_solo_focus :
The electrical switch on the side of the trans that tells the gears is called “transaxl-range-sensor”. & the “external manual shift lever” goes over that.
& thanks for informing me on the shift parts needed out of 08-11’.
Super Moderator
slow_solo_focus :
so the plate thing is the external manual shift lever?
Super Moderator
Discussion Starter #17
thanks all.
Looks I’ll be getting the tools piece by piece.
Doing the researching in what I need is the hard part tho’…
Discussion Starter #19
Bellhousings are different between zetec and dtec.
yes.
that’s why we were discussing the possibility of swapping bellhousing’s.
until someone proves otherwise, it looks to be a fruitless endeavor.
so now we’re looking towards what tools would be needed to do a basic rebuild.
& where to get them.
1 - 19 of 19 Posts
