looking to get some feedback on what others think, and what I should do/check to fix this problem.
I'm selling my Turbo-SVT focus and wanted to make sure the tune was set safely for test-drivers, etc
here is what happened:
1) Car was running with the tune that got put on in 05 (I wanted to make sure it was safe for people to test drive so I attempted to get some data log data) I couldn't get the data log to work (out of date predator)
2) I restored the original back up, and then upgraded the predator
3) Had Tom send me the same tune that he still had on file from 05, loaded that tune, car started for 2 minutes (ran VERY rough, then stalled out)
4) car has never cranked again...
my odometer is reading numbers so as far as I know that means that the ECU is still good (correct me if I'm wrong). Are there certain wires, switches I should check?
- I've checked fuses/relays.
- jumped the starter (it cranked but never started)
- restored the original backup (still doesn't crank)
any other suggestions. if its not running I'm going to lose a lot of money in the sale.
thanks
thanks
