svt upgrade clutch flywheel
1547 12
any ideas car is stock maybe aluminum flywheel
1 - 13 of 13 Posts
· Premium Member
Moved to the performance section where you can find more info..
Just what you want & future plans can affect the choice, the "better" clutches & flywheels aren't great for a stock DD. (even SVT)
Small step up instead of a large one if you don't have plans for a Turbo...
· Premium Member
pasta's running a stock SVT in Queens, so his situation is a bit different.
Light flywheel & clutch happiest with fast engagement could be a PITA in NYC traffic.
If I hadn't seen people who wanted to switch back to something less aggressive than what they bought, I wouldn't mention thinking about the best fit for the application.
· Registered
I just installed a spec aluminum with stage one clutch kit in the lemons car. I can give you a review in a month on it if you'd like. But I would recommend the aluminum due to weight loses alone.
· Premium Member
pasta - it's worth thinking about for when you need one, quality replacement is fine if you're happy with it now but replacement time is perfect for making a change.
I play devil's advocate just because almost ANY change has a plus & minus. When the plus is what you want, the "minus" can become unimportant.
1 - 13 of 13 Posts
