I would like this guy to come on here and answer these questions
What are you doing for tuning ?
Adding a return fuel system and worthless FMU isnt tuning , there isnt a problem with the stock pump , lines , and ECU making 300+HP at the wheels so why change it , You talk about making it cost less then why add all this worthless crap
How are you going to deal with the existing fuel pump seeing more PSI through the FRPS from the new added pump and the stock pump shutting down to maintain 39.4PSI that the ECU is set to target , you will have SURG from he!!, Return fuel systems are not needed on the Focus below 350HP at the wheels
Why do a return fuel system then add a POS FMU , if you do a return fuel system and a adjustable fuel psi regulator why not just make the fuel psi regulator a rise and rate where it does a 1 to 1 to boost for fuel?
I can tell you havent done a Focus yet and if you did do one and it was done this way it isnt right , Do do it right and proper it cost money and a quality kit like the roush has a proper tune with proper fueling with proper sized injectors not a hodg podg of worthless crap thrown at it in the form of a turbo kit
You think 4000 is high when i was building them it cost 5200.00 but my kits have yet to be matched in performance HP or TQ
mustanggtandgsxr: stay away from this kit in my opinion its worthless as it is
I welcome Jose to come in and comment on what i have said , I also would like to know where the "I have installed dozens of systems on the Focus" dozens of Focus kits he has installed are at , I havent seen one on FF or fj yet , has anyone else ?
Some pictures maybe , some dynos ?
