1 - 14 of 14 Posts
Has anyone ever swapped an SVT motor and Tranny into a Focus that originally had a 2.0 Duratec? If so what all is needed Other than the obvious Motor, tranny, ECU?
wiring harness and most likely the body harness too and maybe the GEM modules...
but why switch from a motor with a superior design?
I'm just tossing the idea around i for sure want to go turbo with either one. The Xios Kit for the SVT motor is putting out some impressive numbers. Has anyone ever done the swap? And if i dont do that i would probably opt for Swapping in a 2.3 Duratec. Where is a good place to look for Used motors?
br/o/stang
Build your duratec, once you get rid of the stock rods and pistons its superior
Deaf Focus Fanatic
find a 2.3 duratec and turbo it :)
Is ebay the best way Find used Engines? Dont most people keep the Stock cams when Boosting the Duratec's?
Discussion Starter #10
So is Ebay the best way to find a used engine? Or is there a certain websight thats good?
check out LKQ online. thats where i got my 90$ 2liter which will be a frankenstein by the time im done with it.
1 - 14 of 14 Posts
