I just installed an SVT Sub/Amp into my 2005 ZX3 and everything went really smoothly. Only problem is that I'm not getting nearly the level out of the sub that I think I should. I know it's just the factory sub, but I think it should be able to do better than this...
I know that the factory amp has a balanced input. Ford uses this to send the signal long distances without having to worry about noise being induced. I hooked up my Alpine subwoofer output (RCA +) to one of the two signal input wires on the factory sub connector. I think the problem is that a balanced input has a summing stage where the two signals are combined back together (and noise eliminated) - but now the summing stage is only getting one input and therefore the signal is at a lower level than it should be. The amp then doesn't have the gain to give me the power that I want.
I have the subwoofer output level on the Alpine turned up all the way, but there's not the really noticable difference I would expect when adding a subwoofer.
Has anyone else run into this problem when using the factory sub with an aftermarket head unit? Any solutions?
I'm considering my options: unbalanced to balanced converter, aftermarket amp, etc. My headunit actually has two subwoofer outputs that I might be able to sum together to increase the signal strength, but the only passive circuits I've seen for doing this also attenuate the signal - so the problem would still be there.
Thanks.
Thanks.
