1 - 17 of 17 Posts
· Registered
I've been experienced a stutter problem consistantly at 2900-3000 rpms. Changed the fuel filter, plugs, wires and coil with NO change. I've put 104 Octane in it, ran injector cleaner, ... ANY SUGGESTIONS???!!!
· Focus "Sleeper"
The infamous SVT shutter! Upgrade your electrical connections. From what I understand, that is a cheap way to fix that problem. Give me a couple minutes, I will look up the how to.
· Registered
Discussion Starter · #6 ·
I haven't experienced that.
Mine is worst in second gear slowly speeding up to 3000 rpms and thats when it ''hops" and significantly when im in the throttle. Up to 2800 it wraps then ''misses'' up to 3000 and gets back at it...
· Focus "Sleeper"
Found it!
http://www.focuscanada.net/forum/index.php?showtopic=8122
You dont need all the things listed on this page. All you need is the wire, the connections, couple sockets, and pliers to close/crimp the ends. Thats all I used. Go to your nearest stereo place, they got the right sized wire and connections you need.
Good luck!
· Focus "Sleeper"
Its labeled a stereo upgrade, but the problem with your stuttering at 3K has to do with the electrical connections being sub-standard. This should fix you up. Its like a $25 upgrade. If this doesnt do it, its time to get yourself a tune!
· Registered
Discussion Starter · #10 ·
Found it!
Good luck!
You're kidding me! I'll get on this asap. Who would have thought this would have anything to do with it?
· Focus "Sleeper"
The flash for the supercharger is a tune. So scratch that idea.
· Registered
My moms focus has the same kind of problem, from what i understand. Her car starts missing at idle (mostly at a red light) It sometimes even stalls. We changed the coils, she got an oil change, changed the fuel filter (although the old one seemed fine). could it be the fuel pump??
· Focus "Sleeper"
I dont know. You will have to start a thread, you will get more people who know about that kind of problem to help you. Thats your best bet. Can almost garantee someone on here will know what to do.
1 - 17 of 17 Posts
