1 - 4 of 4 Posts
I'm looking at purchasing front and rear rotors for an '04 SVT....what is the 'stock' rear disc size? I'm seeing options of 10" and 11". I know the fronts are larger than the rears, but can you install the 'larger' rear disc with the stock caliper mounts?
British American Tansfer (www.batinc.met) lists the stock rear SVT as 278 x 11 mm. Not sure the larger disc would work with the stock caliper mounts. When I but larger rotors on the Contour I had before the Focus I had to get a mounting kit as part of the change
The SVT rears are 11" as stated. The 10" ones are for AdvanceTrac rears.
1 - 4 of 4 Posts
