Hello all I just bought the svt with a bad motor went online and had one shipped with 85k on it got it back ran like crap changed plugs with E3s bad mistake did some reading and now have copper plugs gaps at .60 ran better but still popping threw the intake it was off one tooth on timing so i brought it to a shop to get done. then i changed the vct and the valve cover gasket now i brought it to a good friend of mine who was a master tech a a lot of dealerships and had been around for a long time with cars. he checked the timing said it was dead on but i had a hose clamp on my pcv the boot broke and i put a heater hose on it and used the clamp to keep it from blocking the air. I rigged up some vacume lines and put a 90 degree bend on the pcv here is were im at now. When the car is cold (morning work drives) Car has good power its hard to start and the idol goes to like 3 grand then goes back down. Then about 10-15 mins into my drive when the car gets to normal temp it starts to dog down bad like half the power? The motor sounds hissy? like a vacuum leak but when i spray staring fluid around the evap lines and everywere else the idol don’t go up [dunno].
I have a smoke tester and a snap-on solus scanner if this helps any one if they want me to run any type of test on the car. I have almost a full shop to be honest. any help will be much appreciated
codes are p1383?
codes are p1383?
