Here's the story: About a month ago just before the second run at an auto-x noticed the oil and water temp in the red. Put heater on max right away and cooled almost instantly, oil first. With heat on temp stayed normal rest of day. Coolant and oil level is good. Next day checked it out cooling system had pressure, saw the fan run. Drove next two weeks normally without heat on , no overheating. Next auto-x , just finished first run, noticed oil temp start to climb with water temp going up right after. Again turning heater on brought back to normal level much to quickly. Again able to drive around between events with heater off and no overheating problem , even in light stop and go traffic and hotter weather. Couple people suggest electrical gremlins but I don't trust that thought enough to leave the gauges in the red. Any ideas?[?|]
