1 - 15 of 15 Posts
Just thought I woudl pass along some information to any of you interested. I have the Big Boost Kit installed on my SVT and have been testing it out.
Power numbers
212whp
169wtq
Track Times
14.24s @ 100.28mph
teh tranny killer
awsome..though i woulda thought the quarter mile times would be lower...still i bet its alotta fun to drive [thumb]
Here are my best two track times from Saturday. As you can see the 60ft needs some improvement. I have pulled a 2.21 60ft time before I got the big boost kit. So their is till some room for improvement. I think if I had a set of drag radials the car defintily would be in the 13's. And yes it is a blast to drive.
60ft -- 2.377
330ft -- 6.248
1/8th -- 9.358
MPH -- 79.38
1000ft -- 12.010
1/4 -- 14.264
MPH -- 100.52
60ft -- 2.332
330ft -- 6.215
1/8th -- 9.332
MPH -- 79.35
1000ft -- 11.988
1/4 -- 14.243
MPH -- 100.28
QuickSilverSVT said:
what was the final price of the kit the big boost kit and the install price
The kit isnt out yet for sale, from what I know should be comming out June sometime. I'm not sure what the price will be. From my understanding probably could get the JRSC and the Big Boost kit for around 3000.
The Big Boost kit comes with
3in Pulley ( good for 11lbs of boost )
Serpintine Belt
42lbs injectors
New MAF sensor (used in the stock houseing)
Reflash of the ECU
if the kit sint out yetm then how do you have it on your car? and if you are only running 210 whp and 170fpt that doesnt seem to good cause Im running 200 whp and 170 wfpt with stock jrsc
Discussion Starter #10
And stock boost is max of 7lbs with the 3.6" Pulley.
Numbers can be decieving. Depends on which dyno you are using and which gear they are useing durring the dyno pull. I can guaruntee you that the car feels much different than with the stock boost. And I was in the right place at the right time. The kit is comming out shortly and was using my car as a test car.
What kind of dyno was it? Was it a Dynapack?
so who did you buy your SC threw was it Jackson or another site ? also where or what sites will the big boost kit be avaiable ?
Discussion Starter #14
I got my JRSC a while ago, last August through a local shop who got it directly from Jackson Racing. The Big boost kits should be available soon hopefully. The guys up at McNews Automotive you should beable to get the kits through them.
1 - 15 of 15 Posts
