1 - 4 of 4 Posts
what modifications need to be done to a standard svt header for it to work on a normal zetec. i know the power steering line should be insulated as well as possible to avoid frying the fluid, the header itself will be wrapped aswell.
I believe there is a EGR bung that is sapposed to be put in but i think i may just delete the EGR when i get it tuned.
anything else?
I would think aobut just getting the svt p/s line itself. It's routed much better. if you are going to eliminate your egr than you will be fine. That's about it really i believe. You'll need the 02 extensions and you'll prob just tune out the 2nd 02 sensor too. so you should be good.
  • Like
Reactions: silveib
1 - 4 of 4 Posts
