1 - 20 of 88 Posts
Hello Focus Community,
This thread is intended to consolidate our combined knowledge about the SVT Getrag MT285 transmission information, parts suppliers, and locations for acquiring replacements units into a singular thread. Please provide your feedback and sources and I will update the first post to make this thread better!
Thank you,
RevLimit
Getrag MT285 Information Thread
Content:
-Getrag SVT/Mini Cooper S Gear Ration Comparison
-Getrag Transmission Oil
- Parts Sources
CV Axles​
Getrag Internals​
Getrag Transmission Shops​
- MISC
- Photos
Getrag SVT/Mini Cooper S Comparison
SVT Focus gear ratios:
(Image Source)
...Gear......Lay......Lay:diff....Overall
...Ratio.....Shaft....Ratio.......Ratio
1 4.44:1.....1.......2.88:1.....12.7:1
2 2.67:1.....1.......2.88:1......7.7:1
3 1.33:1.....2.......4.25:1......5.7:1
4 1.08:1.....2.......4.25:1......4.6:1
5 1.33:1.....1.......2.88:1......3.8:1
6 1.08:1.....1.......2.88:1......3.1:1
R 2.82:1.....2.......4.25:1.....12.0:1
Mini Cooper S gear ratios:
1 4.167:1.....1.......2.74:1.....11.43:1
2 2.619:1.....1.......2.74:1......7.18:1
3 1.333:1.....2.......4.05:1......5.40:1
4 1.089:1.....2.......4.05:1......4.41:1
5 1.333:1.....1.......2.74:1......3.66:1
6 1.089:1.....1.......2.74:1......2.97:1
R 2.748:1.....2.......4.05:1.....11.13:1
Sources:
FocalJet Thread - "SVT/Mini Cooper S Tranny" (Link)
NOTICE:
There is a lot of debate about which fluid should be used inside the SVT Getrag transmission. Since I've not seen a scientific explanation in favor of using a specific type, I'm going to list the most commonly recommended fluids below.
Specs:
Getrag MT285 Fluid Capacity: 2.2 quarts.
List:
Motorcraft Full Synthetic Manual Transmission Fluid (Link)
Part Number: XT-M5-QS
Redline MTL 75w90 (Link)
Part Number: 50304
AMSOIL Manual Synchromesh Transmission Fluid 5W-30 (Link)
Part Number: AMSOIL-MTFQT
Valvoline Synchromesh MTF (Link - Page 5)
UPC: 74130030947
(Not Recommended) Royal Purple Synchromax (Link)
Part Number: 12512
Note: Thanks to FF user spikedbat for verifying that Royal Purple does NOT recommend using Synchromax in our transmission. They recommend using Royal Purple 31140 HPS 10W-40 instead. Anyone currently using Sychromax in their transmission should drain and replace ASAP, see (Link) & (Link)
Royal Purple HPS 10W-40 (Link)
Part Number: 31140
Sources:
FocalJet Thread - "opinions on transmission fluid for Getrag" (Link)
FocusFanatics Thread - "Getrag gear oil (hopefully the final thread on it)" (Link)
BobIsTheOilGuy Thread - "What Trans fluid? MINI Cooper S - Getrag 6-speed" (Link)
YouTube - Ed Peters, Chrysler/Dodge SRT Engineer, discussing transmission fluid types and manual trans breakdown. (Link)
Parts Sources
Note: Be extremely careful when shopping for a 'new' CV axle. Every new/frankenstein Chinese axle that I have examined or attempted to utilize ended up never being installed or had to be returned. I have not been able to find an American shop that will rebuild a CV axle. See the photos section below for examples.
Problems To Look For:
- Incorrect fluid channel geometry on transmission input shaft. This will lead to leaking fluid.
- Improperly sized guide rod bearing on passenger side CV axle. If the shift is not perfectly centered into the transmission, you will get transmission noise/grinding at various speeds.
- Damaged input shift splines.
New CV Axles
EBay Axle Store
New SVT CV Axle Set - $166.00 (Link)
Ford Direct Parts
(Link)
$363.50
Left
Part Number: 3B437(TX-395)
$441.06
(Link)
Right
Part Number: 3B436(TX-394)
Replacement Transmission Sources
Speedway Recyclers
www.speedwayrecyclers.com
Note: Speedway Recyclers is an SVT only scrapyard. They have a decent number of SVT only parts.
Car-Parts.com
www.car-part.com
Note: You will need to search for replacement transmission for 2002 or 2004. Their database is missing the SVT (6-speed) option for 2003. Be sure to verify the transmission model when you call.
Getrag Replacement Internals
Cobra Transmissions
(Link)
SVT (6 Speed) (Fwd), Synchro & Bearing, Gasket and Seal Kit, Focus SVT DOHC 00-Up (2.0L) (Getrag) (Ford)
Part#: CT-BK336WS
Note: Contact For Availability
Shops With Getrag Transmission Experience
AutoTech
www.autotech.com
Cobra Transmission
www.cobratransmission.com
Miscellaneous Information
Google Spreadsheet showing top speed limits based on wheel/tire size (Link)
Getrag Tear-down and Differential Install (Link)
Getrag Counter Weight Removal Guide (Link)
Modified Getrag Gearing Ratios (Link)
Shifter Bushing Install (Link)
Photos
Shifter linkage with shifter weight present at top.
Top - OEM Passenger Side CV Axle Transmission Input Shaft
Bottom - New Chinese Passenger Side CV Axle Transmission Input Shaft
Note the bottom shaft has incorrect fluid channel geometry.
Another angle
Top - OEM
Note that the guide bearing on the bottom shaft was not pressed into the right position.
Shifter Bushing
Meh.
Holy hot sauce! Great thread. [thumb]
Such a huge help. Just bought my svt last week and even with that transmission thread already stickied I was still unsure of what to use.
Grey Friar
Excellent!!! Don't see it getting better, but we can try.
Should be a sticky!
Thank you for this, but Synchromax should be removed and RP 75w90 Maxx gear & RP 10w40 Motor oil should be added to fluids as this is what RP Officially recommends in the Getrag285 NOT Synchromax.
I need to check back with that Mini guy on internal parts if I get a hold of him ill post back here
Discussion Starter · #9 ·
Before I make the correction, could you provide me with an official quote/link from Royal Purple?
I would remove the oil recommendation all together. Too many opinions on what to use.
I think it's relevant for us to list the recommended oil types in this thread. I would rather owners be able to find all of the recommend oils in once place, and give them the ability to research my sources to make up their own minds on the oil types.
So far I have not found an analytical scientific explanation of which oil type we should really be using. I think the safest bet is to use the Motorcraft XT-M5-QS which is why I placed it at the top of the list.
Post out to everyone.
I would love to have a longer final gear in the transmission for lower RPMs on the highway. I would need to hookup a wide-band O2 sensor and perform data logging to build a fuel map in order to calculate the optimal final gearing for higher speed/better MPG driving. I think having a longer final gear we could achieve better MPG and keep the RPMs lower on the highway - 3,000 RPMs at 70MPG is retarded for 6th gear...
FF's Night Security
I have a few more adds for the trans fluid. Had to replace the clutch and stuff in my in laws so I did a lot of searching and stuff. I did find out that the Mini trans takes a GL-4 type fluid which is hard to find. Most fluids are a GL-5 which say they are backwards compatible but is still harsher on the soft parts than a strait GL-4 fluid. Just something to keep in mind when searching for trans fluid. As for our trans I can only find the Ford fluid as recommended, besides all of our opinions.
Grey Friar
^Good call... all brass synchro transmissions need GL-4 fluids. GL-5 (or GL-4/GL-5) rated fluids will corrode/strip yellow metals (brass) and thus destroy synchros.
Also, some of the lube recommendations on page one are not completely consistent with the makers recommendations (i.e. Redline lists their MTL 75W80 GL-4 Gear Oil for our cars, not the MT-90 75W90 GL-4 Gear Oil).
Thank you,
RevLimit
Content:
- Parts Sources
CV Axles​
Getrag Internals​
- MISC
(Image Source)
Sources:
NOTICE:
Specs:
List:
Part Number: 12512
Part Number: 50304
UPC: 74130030947
Sources:
Parts Sources
New CV Axles
EBay Axle Store
Ford Direct Parts
(Link)
$363.50
Left
$441.06
(Link)
Right
Speedway Recyclers
Car-Parts.com
www.car-part.com
Cobra Transmissions
(Link)
Part#: CT-BK336WS
AutoTech
www.autotech.com
Cobra Transmission
I am looking for the cadmium coated shift linkage tower selector assembly. (has counter weight and where the trans side shifter cable attaches) bushings honestly the whole assembly. Please let me know
FF Affiliate
75/90 is WAY to heavy an oil for the Getreg in my opinion, if you ask the RP engineer ( not the idiot on the phone trying to sell you something ) its a "recommendation" and they have never tested it on a Getreg
I use Mobile Synthetic 5/50 in hundreds of Foci Trans and never one issues and there making from 150hp to 600 hp , and some been running like this over 200,000
Gear oil and engine oil weights are measured differently. A 50wt engine oil is thicker than a 90wt gear oil. Your selection will probably result in very very good cold weather performance though, before the trans warms up, and as you have found will continue to perform just fine. As many have learned, transmission gears aren't terribly picky about fluid thickness. They just don't care. Generally a thinner fluid is run in a transmission, but because it's a transaxle, it has a differential in it. Diffs generally run slightly thicker fluid. They went for the thicker to protect the diff, since they knew the trans gears wouldn't give a crap. The syncros and sleeves however, care a little more. Stick with a GL4 fluid to prevent eating the syncros over time, and play with viscosity if you so choose. However, the ford spec'd fluid is apparently rated as a 75w-90. So there you go.
Not this exact transmission. One of the mini cooper models uses it with different gear ratios and possibly a slightly different casing to fit the different ratio.
i just need the linkage.. if it is the same that would open up my searching options. definatly something to look into. It has been a near impossible task to find these parts with out buying the whole transmission. I have traveled the whole state of Washington now..
1 - 20 of 88 Posts
