1 - 2 of 2 Posts
hey guys i have an 05 zx3 and i was hopein to upgrade my brakes with the stock svt setup. i was just kinda wonderin if they would fit my car and if they will fit inside my stock (for now) steel wheels. any help is appreciated
thanx
tyler
I believe the SVT fronts need a minimum of 16" wheels up front to fit inside. And yes they will fit your 05 no problem. Basically what you need for the fronts are the calipers, mounting brackets, pads and rotors. The rears are a bit more tricky. Basically everything down to the rear trailing arm is replaced. lol. CFM sells kits.
1 - 2 of 2 Posts
