1 - 4 of 4 Posts
I just bought a 2003 svt, and am about to install an mtx amp, but am having a problem. Where are you supposed to run the power wire through to the engine? Every thing is so congested under the hood its hard to see anything, and Im having trouble finding a hole in the firewall to run the wire through....... any suggestions would be greatly appreciated...
rob
There are a couple of plastic panels behind the brake pedal. I drilled a small hole through one and the wire ends up directly behind the battery.
If you are scared to drill through plastic, there is supposed to be access through the left door hinge area. Other threads have covered this. Do a search.
1 - 4 of 4 Posts
