In May during a vacation, I ran into a rock slide and needed emergency repairs which included replacement of the broken springs and struts and the jawbone motor mount which had nearly come apart for my 2001 Focus ZTS. While it was in the shop repairs were done using OEM parts; however, they did not tell me how they had replaced the motor mount. When I left the shop I immediately found that I had a 15 to 18 percent reduction in gas mileage, down from 31-32 mpg to about 25 mpg. The car was operating well, but the mileage was way down and stayed that way.
Finally, after checking and replacing the plugs and rotation and balance to my fairly new tires but seeing no change in the mileage, I had it on the rack and found that the cross member that attaches to the motor mount had been removed - using a torch. This subframe cross member was distorted and misaligned and left in a weakened state.
I also noted that the now rear tires had extraordinary wear with some cupping. The front tires exhibited the start of wear.
The original mechanics denied that this was the cause of the poor gas mileage and extreme wear of the tires although when I replaced the cross member and had it realigned it smoothed out the ride and the gas mileage went back up to 31 mpg highway.
Apparently, if they had aligned the vehicle it was done before the motor mount was replaced. But they stated that this cross member would not be a problem and had nothing to do with the loss of gas mileage. They stated that the cross member had nothing to do with the alignment.
Did I do the right thing in replacing the cross member? And, would it have any effect on the suspension?
I have pictures of that subframe cross member before it was replaced, if necessary.
