1 - 20 of 32 Posts
Tom, If you had to choose a supercharger work with, which one would it be. Personlly I was looking at the FS/VF charger, but after looking at the dyno sheet, i was thinking im almost making almost the same numbers N/A. Procharger dont seem very difficult to install, unlike vortech. and it put up some good numbers.
I suppose to be saving for a wedding, but she pushing it back for some years. ill put the money to good use.
Focused Focus
I cant speak for Tom, but i do know that he likes the Prochargers. I honestly dont think, for the money, theres a better option than the Procharger. Most anyone that has minimal mechanical knowledge and basic hand tools, can install it in an afternoon.
ive been searching for pictures...never seen one install in a focus
Discussion Starter · #4 ·
ive been searching for pictures...never seen one install in a focus. i know know what needs to be moved moded.
look on b16 pics
b16 i see you have a procharger, what kinds of 1/4 mile times do you get? back on topic: i too have heard nothing but good things about the procharger setup. that is what i am most likely going to get after a year of reading posts about all the others.
FF Affiliate
NOOOOO! ! ! ! In my opinion the fs/vf SC is the worst SC on the market by far. The ProCharger is the way to go
Discussion Starter · #8 ·
since i couldnt see anything...basicly everything is under the car?
Discussion Starter · #9 ·
would 10.5:1 CR would run into a problem?
FF Affiliate
More of a problem then 9.5 but nothing a SC and a good tune couldnt handle , with SC you want more compression then with a Turbo in my opinion
Focused Focus
I've read that the FMIC sits a little low, but other than that it should be fine.
I'd get the Procharger or Vortech unit myself - the Powerworks is way too expensive!
Discussion Starter · #14 ·
what numbers you up putting up?
Focused Focus
On a SVT or ST170, basically stock, you would see appx +/- 260hp at the tires and appx. 220torque at 10lbs.
Focused Focus
I am getting into auto-x and the power of the Procharger and the way the power comes on would have been crazy on an auto-x course. I sold it and did some engine work to get a bit more all motor for auto-x. It wouldnt be as bad now that the Torsen's are out but its done now. I have thought of going back and just using an 8lb kit. Anymore than that i think would be kind of crazy on a course. PM me about your vacation...........
Discussion Starter · #18 ·
i sould be putting up crazy numbers then. i was beating SVTF's when i had the stock exhaust manifold. to optimize the power should i change the udp? anything else i can do??
Discussion Starter · #20 ·
Yes its going to be later, but its going to happen. why dont you recomend it? just curious
1 - 20 of 32 Posts
