1 - 10 of 10 Posts
i would like to maybe go with a supercharger so i want to know which supercharger to go with that is around 2,000 or around there im actually looking for the complete kit. so which one should i go with thanx guys.
DTF
bout the only way you are going to find one that cheap is going to be a used system. however for around 3k you have a couple more options to look into. might want to just save a bit more and then look into the procharger setup.
You're not going to find one for 2k. Even a used JRSC is gonna be more then that. You really need to safe up a bit. For 3k you can get a JRSC, but I sugest a Vortech H.O. Much more power with the basic set up.
o ok im just looking at my options so i guess i will save up a bit more and up my rang to 3,000 thanx guys
Focused Focus
If you can afford to go $2k and maybe $3k, go ahead and save up a bit more and do it right with a Procharger or a turbo set up. Will be glad you did in the long run.
i went turbo.
And the install with be much easier (compared to the other sc's...turbos are a fairly easy install too).
Save for a procharger. The JRSC+BBK is great but i would rather have a procharger personally.
i am thinking about getting a little for power in my focus lx.. im not for sure if i chould even put anything in.. what do you guys think?
1 - 10 of 10 Posts
