1 - 18 of 18 Posts
Hello,
I'll install a supercharger into my Focus 2003 Zetec 2.0. If i were in USA, i would buy the Jackson Racing Kit and woud be done.
But since i'm not, i need to buy in parts, so i need some help.
1st i want to leave the engine as much as possible as a stock one
I bought an EATON m62, a new Intake to hold the eaton m62 (very similar to the JR intake).
I also bought a K&N High performance filter (to fit in stock box) and a Ford Racing SVT Snorkel, to give more fresh air.
Now i need to go to the Injectors.
Should i buy the Ford racing 30lbs/h or the 42lbs/h?
BTW Whats the stock injecor flow?
Since i'll not be able to reprogram the ECU, i'm thinking to buy a reprogrammed MAF, or a
A Diablo MAF Interface as this one
And what about the Throttle Body ? what you guys suggest me?
BTW, the car will run at 0.4bar
Thanks a lot
i'm running 8 lbs of boost and i have 42 lbs injectors. i would def go with those.
What about the TB ? should i replace the stock one for a 65mm? or the boost with the eaton M62 will make no difference?
About the Diablo Maf ia, where can i buy it (that ships out of USA) ?
And about Injectors, a friend of mine offered me a set of BOSCH injectors, from the ST170 but he does not know the flow rate. the model is: Part no.B280 434 275/04 103 078 014
Anyone knows the flow rate for those injectors?
go with the 65mm. i bought my diablo mafia from cfm. i would still go with aftermarket injectors.
Discussion Starter #6 (Edited)
I can buy the injectors here in Brazil. But here we dont use lbs/hour. we use ml/minute (milliliter). Anyone knows how to convert it?
BTW, whats the stock flow rate?
Fins Up!
Here is a list of every single little part that you get with a jackson racing kit, you can order them buy part number on jackson racing.com but im not sure about shipping but i thought i would try to help you out
Item No. Description Quantity
995-000 SUPERCHARGER SYSTEM 1.00
988-042 S/C SUPPORT BRACKET KIT 3 1.00
051-081 WASHER, FLAT, M10 2.00
051-084 BOLT, HEX, M10-1.50 X 50 G8.8 2.00
051-186 NUT,FLANGED,8X1.25,12AF 1.00
051-505 BOLT FLANGED M8X25X1.25 12 AF 1.00
051-506 BOLT, HEX FLANGE M8-1.25 X 30 1.00
051-657 BRACKET, S/C SUPPORT STRAP 1.00
051-658 BRACKET, S/C SUPPORT LOWER 1.00
772-316 ALUMINUM, 2.7X4.7X1.125 1.00
772-217 BLACK, ANODIZE 0.56
988-105 ALT/BELT DRIVE BRACKET - FOCUS 1.00
051-081 WASHER, FLAT, M10 1.00
051-505 BOLT, HEX FLANGE M8-1.25 X 25 2.00
051-627 PULLEY, 2.0IN IDLER, PLASTIC 1.00
051-762 BOLT,HEX FLANGE,M10 X1.25 X 30 1.00
052-170 BRACKET, ALTERNATOR - GEN. 2 1.00
988-211 INTAKE MANIFOLD ASSY - FOCUS 1.00
051-098 BYPASS VALVE 1.00
051-121 SCREW, SHCS, M6 X 1.0 X 16 4.00
051-142 HOSE BARB, 5/32 VACUUM 2.00
051-144 HOSE, SILICONE, 1.5 ID X 1.25 1.00
051-189 CLAMP, HOSE, MINI, 2INCH 2.00
051-364 PLUG, PIPE, AH, 1/4 NPT 1.00
051-503 BOLT M8 X 0.75 X 10 WI PLUG 1.00
051-529 GASKET, JR BYPASS-MANIFOLD 1.00
051-553 CLIP RETAINING 7/32 VACUUM 1.00
051-660 INTAKE MANIFOLD - FOCUS 1.00
051-794 GASKET, INTAKE MANIFOLD 1.00
051-796 HOSE, VACUUM, 7/32 X 14 IN 1.00
051-551 HOSE, VACUUM, 7/32 ID, BULK 14.00
051-797 HOSE BARB,1/4NPT X 1/2 X 45DEG 1.00
988-307 SUPERCHARGER ASSEMBLY - FOCUS 1.00
051-122 STUD, M8 X 1.25 X 40 1.00
051-142 HOSE BARB, 5/32 VACUUM 1.00
051-207 AHCS M8X1.25X25 2.00
051-528 GASKET,GEN3 S/C-TB ADAPTOR 1.00
051-656 S/C GEN3 M45 CW 3.0-6R 1.00
051-662 TB ADAPTER FOCUS 1.00
051-680 HOSE BARB, 3/8 VACUUM 1.00
051-783 AHCS, M8 X 1.25 X 55 1.00
051-938 NUT, FLANGE, M8X1.25, 10MM A/F 1.00
988-423 HOSE BAG 1.00
051-134 VACUUM TEE 3/8 1.00
051-235 CLAMP, HOSE, SAE NO. 44 2.00
051-259 HOSE, VACUUM, 5/32 IN., BULK 35.00
051-389 TEE, VACUUM, 3/16 1.00
051-513 CLAMP, HOSE, NO 8 2.00
051-665 HOSE, PCV, 1/2IN BULK 2.00
051-669 HOSE, FLEX LOPRENE 1.00
051-758 HOSE, SILICONE, 7MM ID, BLACK 32.00
052-201 TEE, VACUUM, 3/8 X 1/4 X 3/8 1.00
052-211 HOSE, VACUUM, 1/4, BULK 6.00
770-268 LOOM SLIT, CONVOLUDED, 1/2 DIA 36.00
051-320 ELBOW,VACUUM, 1/8X11/64X90 DEG 1.00
051-372 SLIT LOOM.1/4 INCH 12.00
163-655 HOSE, VACUUM, BLACK PLASTIC 3.00
988-703 GASKETS - LOCTITE - ZIP TIES 1.00
051-016 CABLE TIE 8.00
220-136 REMOVABLE THREADLOCKER 1.00
051-525 GASKET, M45 S/C MANIFOLD 1.00
051-395 SPADE CON, MALE, 18-22 GA 1.00
051-387 SPADE CON, FEMALE, 22-18 GA 1.00
988-812 INSTRUCTIONS AND STICKERS 1.00
051-473 JR WARRANTY CARD 1.00
051-676 INSTRUCTIONS FOR FOCUS 1.00
052-010 STICKER, PREMIUM FUEL REQUIRED 1.00
052-282 CARB E.O. STICKER 1.00
988-913 HARDWARE BAG 1.00
051-004 BOLT,HEX FLANGE,M6 X 1.00 X 15 4.00
051-074 WASHER, FLAT, M8 4.00
051-075 WASHER, LOCK, M8 4.00
051-119 BOLT, HEX FLANGE M6-1.0 X 10 1.00
051-125 STUD, FULL THREAD 8 X 50 X1.25 9.00
051-127 BOLT, HEX FLANGE M8-1.25 X 20 1.00
051-135 BOLT, HEX FLANGE M8-1.25 X 40 1.00
051-186 NUT, HEX FLANGE M8-1.25 9.00
051-663 SCREW, SET, M8 X 1.25 X 50 2.00
051-677 STUD, M10 X 1.5 X 50 1.00
051-678 NUT, FLANGE, M10 X 1.5, 15 AF 1.00
051-714 BRACKET, SC - ALTERNATOR 1.00
051-717 SPACER, .33 ID X .63 OD X .33 1.00
770-137 ALUMINUM, ROD, 0.625 0.53
051-718 SPACER, .33 ID X .63 OD X 1.80 1.00
770-137 ALUMINUM, ROD, 0.625 2.03
051-754 ALLEN WRENCH, 4MM 1.00
051-761 BOLT,HEX, M8 X 1.25 X 90 4.00
051-788 BOLT, HEX FLANGE M10-1.5 X 40 2.00
052-911 BELT, 6PK2655 1.00
988-915 HARDWARE BAG 1.00
051-003 BOLT, HEX FLANGE,M6 X 1.0 X 12 4.00
051-728 BRACKET, MOUNTING, P/S 1.00
051-729 BRACKET, ADAPTER, P. STEERING 1.00
051-787 NUT, FLANGE, M6 X 1.0, 10 AF 4.00
051-789 SCREW, TAPPING, M6.3-1.81 X 20 1.00
051-696 BADGE, JACKSON RACING 2.00
052-404 DFMM - FOCUS ZX3 1.00
052-405 FUEL CONTROLLER ZX3 1.00
052-071 LICENSE PLATE FRAME, JR 1.00
051-381 BOX, 30 X 15 X 15 350LB TEST 1.00
051-889 BOX, 15 X 15 X 5 1.00
051-942 BOX, 24 X 14 X 14, 275LB TEST 1.00
Discussion Starter #8
No injectors listed, also no Throttle Body
Thats the parts i'm in Need...
BTW, the car will run in Methanol!!
Make sure the M62 you have will put up with the methanol !
Discussion Starter #10
Yes it will. Methanol is stronger then gas. BTW, Methanol was created in Brazil about 30 years as automotive fuel. We have Methanol in ALL and EVERY gas station in the country. Our cars also run in GAS, since they are Flexfuel (runs with Methanol, gas, or any combination of then)
i got my MAFia at mcnewsautomotive.com
Discussion Starter #16
NoOne knows the stock flow rate?
What about a THROTTLE BODY SPACER? Do they really help? or will make no difference on the supercharger?
I meant the internal parts of the M62 ( aluninum and such ) putting up with the methanol. Just check and make sure corrosion won't be an issue.
Discussion Starter #18
Fuel does not go inside the supercharger!
1 - 18 of 18 Posts
