1 - 20 of 29 Posts
I have a Jackson Racing Supercharger running 8 lbs of boost. But i can only really feel the boost at around 5500 RPM. How would I get more boost in the lower RPM range?
Smaller pulley on the SC to overdrive it faster is the traditional way with roots type blowers. If the blower is up in miles, it may need a freshening up.
if you have 8# at 5000rpm, what do you have a WOT at 2000 rpm. you should get 7 or 8 too. if you don't, then you are leaking boost, maybe your bypass valve.
Roots blowers should reach near full boost at all rpm. at least mine did
Discussion Starter #14
Yeah i just looked more into the functions of it. I think the boost is fine because its a linear boost climb. Where full boost is being generated at red-line. But the slightly jumpy idle is a problem? I also run rich so i backfire whilst coasting. Could that be the upstream o2 sensor then?
Yes. Before cat is the more important one. You might be even in limp mode which isn't good for to long.
The ones I have experience with, peak boost is at the highest rpm. It might make 12# at 6500rpm, but it sure isn't making 12#@ 3000rpm.
My experience is mostly just 6-71's and 8-71's on V8's though, nothing with a bypass valve either.
1 - 20 of 29 Posts
