1 - 16 of 16 Posts
Hi guys. I bought a 07 ghia a couple months ago and it came with a lot of little things to do, the next on my list I have no ideia where to start hope u guys can give some light!
My sunroof stoped working one day coming back from work, so I took the motor out and found that the gear had snapped, so I bought a new gear and installed the motor again.
Now the sunroof doesn’t open, if I press the open button it tilts up and then closes again. If I press the open button nothing happens.
Does anyone one what that could be?
Sorry for the long post.
Tia!
I’ll try that tomorrow but did u manage to see the video?
It doesn’t tilt open. It opens and then it closes in seconds.
Discussion Starter #8
I did. Follow the instructions for the logic reset and get back with me.
I tried a couple times no luck.
I’ve noticed that is making a hinge sound before it comes back. So maybe when I took the motor off the ceiling I putted something wrong. I did a video but is difficult to see
https://share.icloud.com/photos/05E91H4pis69S1nmsAhx8BajA#Home
Are you holding the button down or just pushing it once?
Discussion Starter #11
On video I’m just pushing it once to show what happens but I did hold as the instructions.
Discussion Starter #15
So if you hold the button down it does the same thing?
yes it does. If hold the close button it tilts up and close. I can let go in the middle and it will stop in the middle on the tilt. If I press the open button nothing happens
Switch could still have a fault. It is cheaper than a new motor. I would try that first. Or take it to a sunroof specific shop.
1 - 16 of 16 Posts
