2004 SE Wagon with 2.3L
The radiator started leaking so I replaced it with a new one, I did not replace the thermostat because it's too hard to get to and I figured if it ain't broke. Anyway, after replacing the radiator, I flushed the system, and everything was fine for about a month but now it's overheating. The coolant level was over the max full line (how that happened I don't know) so I took some out, but no change. I let the car idle for about 20 minutes no overheating. I tried the thermostat test I found on this site, and it seems to be working normally. As I drove around the temperature went up to 100c and hovered around there, but after a while it begins to fluctuate between 106c and 120c. I pulled over to see if the fans would come on but they are not operational until 121c (I turned the car off at that point). The coolant level was below the MIN mark, so I added coolant but no change. What is going on with this car?
