ok I'm new to this site so please hang with me. My wife drives a 2007 focus and we found a 2000 for cheap i thought i could rob parts from. Bought the car brought it home and decided I could fix it. When we got it it would hardly idle and had no power at any acceleration. I did the following:
1. changed spark plugs
2. cleaned throttle body
3. changed fuel filter
4. changed pcv hose (it was collapsed and had a hole in it)
5. cleaned pcv valve
6. changed air filter
The car now starts and idles fine but it doesnt accelerate right. When you give it gas very slowly it runs fine but when you punch it or try to accelerate fast it wants to stutter and give no power. Eventually it will kick in though and run normal. I'm leaning towards a fuel pump because of the recall they did on this car but hating to spend the money if its a cheaper fix. Running codes P0171 (system to lean) and P0135 (O2 sensor heater circuit malfunction bank 1 sensor 1). anyone have any suggestions? Im gonna replace the spark plug wires as well but dont see this causing the problem just normal maintenance.
EDIT: its a 2000 Zetec DOHC 2.0 with 186k miles automatic wagon. Thanks in advance for help.
