Hello all,
I have just acquired a mk1 (98) ford focus that has a 1.8 petrol engine.
My problem is that if I put my foot down the engine will die to low revs and struggles to accelerate. If I keep my foot down it will 'chug' along build a little then die again and will continue to do so. If I ease off the accelerator to around halfway it will drive reasonably normal. The problem is allot more apparent when under load.
Things I have checked by replacing them with parts from a known working focus are:-
spark plugs
leads
air flow sensor*
coil pack
New fuel filter
I have also tried to eliminate the cat by dropping it from the manifold as I believe this will allow the pressure to escape if it was blocked but no change!
*If I remove the airflow sensor from the intake system the focus will rev fully without cutting out but wont have the power it would normally have I assume because it has been removed; maybe this is why it doesn't die though as it wont be at full power?
I have connected to a standard obd11 diag machine but doesn't show any fault codes.
I am almost at the point of changing the fuel pump, but would this be the problem here? I personally cannot see why this would be an issue if it does rev when not under load and also revs fully if not 'floored'
I am running out of ideas so hoping somebody can give me suggestions to what it could be.
All help appreciated and will keep posting with updates
spark plugs
leads
air flow sensor*
coil pack
New fuel filter
