i have a 2001 focus se with the 2..0 zetec dohc with the 5 speed, it is missing at idle and idles low, and i think it feels like it has almost no power below 4000rpms and if you are going up a hill in 5th gear it will loose speed with the pedal to the floor.
i have put a used engine in that only has 75k miles on it and installed a new clutch,
below is a list of things that i have done to try to fix the problem.
new pcv valve, new pcv hose, EGR delete, new fuel pump, new fuel filter, new fuel injectors, new fuel presser sincer<--- the thing that goes on the end of the fuel rail witch the hose goes into, new spark plugs, i have tried swapping out my coil and plug wires for the old ones that cane on the car as appose to the ones that were on the used engine that i bought, i have also checked for vacuum leaks with smoke tester, and the car shows no ecu codes.
i feel like the car has like no power below 4000rpms, i even raced my dad in his 2002 kia spectra, he has the 1.8l dohc with a 5 speed and from a 20mph roll up to 95mph he pulled about 3 to 4 car links, yet on paper his car is slower, so i dont know if my focus is just that slow or if something is wrong [boxface]
