Posted via FF Mobile when I put the tower, upper rear and front lower and added a rear sway bar. I didn't get an alignment. But when I put on the adjustable toe and adjustable control arms , I did get an alignment and now my car sticks to the road like glue.
Posted via FF Mobile Nice, yea I asked Fswerks and they said they had no issues with auto trans equipped cars and no alignment necessary. What specs are you guys adjusting your cars too? The other day I gave the shop a list of specs, the ones from the alignment sticky and they tried their best to put them in. The guy said because its laser percise it looks like its uneven on the spec sheet, but its really not and that the whole thing is touchy. I thought rear camber was adjustable, theres even a spec for it in the sticky? The guy said no. My drivers side rear is at -.08 and the passanger side is 0.0. ,but I guess it cant be fixed without adjustable rear camber bolts. Will this spec be a big problem? Or if as long as I keep up with rotating tires will it be fine?
Heres the specs they did. Btw they is Mavis.
Original:
Front Camber: -0.3 degress/ 0.3 degrees
Front Toe: -0.62 degrees/ -0.81 degrees (this would explain the extreme right pull I had).
Rear Camber: -0.8 degrees/ 0.0 degrees
Rear Toe: -0.13 degrees/ 0.04 degrees
New:
Camber for front and rear stay the same.
Front Toe: 0.00 degrees/ -0.01 degrees
Rear Toe: 0.05 degrees/ 0.04 degrees.
What are your thoughts?
