1 - 9 of 9 Posts
I installed the Ford racing MX3000 suspension kit on my ZX3 about a year ago and have put 30k miles on it. I love the way the car handles with the Ford racing Argent 17's and Hankook v12 evo tires. The one thing that it did not come with was strut mounts.
I purchased some KYB strut mounts to install with the suspension kit. A year later they are making a loud creaking sound when turning. When parking the car it is very loud and annoying backing into a spot it just creaks like crazy.
Does anyone have a recommendation for another brand I need to get these off the car[rant]?
Thanks,
Paul
w/ my magic bag
Is the large center bolt tight? Should be & are the 3 strut bolt's tight too, hand tight only snug= don't over tighten them or you will break the studs off. I the sway bar end link's tighten or how is the wear on them?
Yes. All of the mentioned bolts are torqued to spec. Those 3 strut mount bolts get torqued to 18ft/lbs yes practically hand tight. Bearing part of mount is spent. I even replaced the end links just to make sure it wasn't them. Thanks for the reply. Any recommendations for mounts?
w/ my magic bag
How 'bout OEM!
What 'bout OEM mount's? Hit up Steve at Toulsey Ford or CFM= Central Florida Motorsport's or BATinc.net
Discussion Starter · #5 ·
They were junk. I used some Autozone mounts as I had a $40 credit so I got the pair for $40. Rides nice without the noises. Lifetime warranty too.
My shock bearings have been in my glovebox for some time now...i really need to replace them. They're like 4$ a pop...or did you replace the top plate and all that jazz as well? How hard was this to do?
w/ my magic bag
Strut mount bearing plate!
You mean, the strut mount bearing plate? You have to remove the strut off the car & have a spring compresser to compress the spring & remove the strut mount & bearing plate. Then assemble the strut again making sure the spring is seated on the strut & install on car & then have the car aligned to at least set your front toe, it's going to be off, when you pull your strut's off. I didn't think they were that cheap=4.00, I'm not use to putting cheap part's on my car's! I'm after quality part's.
Discussion Starter · #8 ·
I'm assuming you are referring to the front struts mounts/bearings.
I had replaced everything struts,boots,bump stops, and bearings so I just replaced the bearings again.
This is a simple job as long as you have control of the spring. If you don't have a spring compressor or press, bring the struts down to a shop they could swap the strut bearings for you cheaply.
My strut bearings are from the dealership in Ford Original Parts bags, no cheap parts here my friend!
1 - 9 of 9 Posts
