2000 Ford Focus ZTS, 5 spd Manual Trans.
Strong engine stutter (car bucks a bit) during acceleration or strain on engine such as going up slight inclines. Speedometer needle jumps when engine stutters. Engine does not stutter when car is in neutral and given gas.
9/7/06 EDIT ----> (radio volume surges in time with engine stutter) This was due to the automatic volume controll increasing volume when seedometer was spiking. now that I have shut off the AVC the radio volume is stable.
New info: I have now noticed that I can hear what I believe is ignition system sending out spark to cyclinders when the radio is on. A faint rapid click that gets louder when the gas is depressed.
Codes
1. Cylinder #4 misfire
2. MAF sensor
Check Engine light is not on but may be burnt out.
9/7/06 Engine light flashed for about a minute or so then went of and came back on solid.
Action taken
Oil Change
MAF sensor Replaced
Ignition wires replaced
Planned Action
1. PCV Valve and tube replacement
2. Fuel Pump Recall replacement
Does anyone have any other ideas or experiences that may help me? Thanks.
Codes
2. MAF sensor
Action taken
Oil Change
MAF sensor Replaced
Planned Action
