1 - 2 of 2 Posts
Trying to replace speakers in my rear doors (2011 Focus SE). Got everything out except for this one screw in the handle of the driver's rear door. The head seems to be completely stripped. I've tried a new bit for more bite, I've JB Welded a bit into there and it just popped back off the screw. I've epoxied a bit into it and it again just popped off. The screw is loose but not all the way out of the door and I can't see any way to get it out. Any other ideas to try? It'd be easy if it wasn't recessed 4" down a tiny tube....
Impact screwdriver would probably do the trick but its a bit sketchy hammering there, not sure if I would want to try that or not. Best bet is probably just buy/borrow a dremel with a longer bit on it and just grind of the head.
1 - 2 of 2 Posts
