OK....so we all know the subframes rust up and cause issues if doing control arms, sway bars, and links. Well today I was a victim of what I thought was just some grit or left over corrosion on the tack welded nut to the sway bar bracket welded to the subframe. You know, just a small torque to get through and be on your merry way. NOPE!
Just a small couple cranks, not even that hard or much resistance for me to think twice, and it was enough to strip the thread. I have no tools to correct this tonight and have a sales meeting 3 hours away tomorrow that I need to leave for in the morning. So what do I do....put the bolt back in, wrench, and cry.
That nut is blocked by the subframe wrapping back up toward the the chassis. What do I do here? I mean, here are what I think my options are...
1. Find a salvage SVTF Subframe.....with this I might as well order all new control arms, links, and hope Ford didnt DISC them.
2. Try and see if some way in God's name, some shop can find a way to either replace that tack weld nut with a new one. (GOOD LUCK WITH THAT. No Clearance.
3. Or go to machine shop or someone with skills with torch and weld and try and locate a wrecked SVTF for a new bracket and have it welded to my existing subframe.
4. Total hack job....just drill through tack welded nut on the bracket and then through the subframe and get a 10.9 Bolt, Nut, and Washer. Like a long alternator bolt.
Somehow I think I screwed myself. Because that bracket needs to get replaced with a new bracket for my aftermarket sway bar. Its OE until my parts came in to Steeda. Aftermarket bushing is not meant for the OE Bracket.
So...when I do sh!t like this...zipties and duck tape can't fix it, I turn to yall!
