Hi there guys, I am having a problem with the starting on my car and was wondering if anyone has had the same issue exactly. There are 2 issues that I am dealing with.
I have the '05 Focus ZX4. Everything is manual, i.e. windows, locks, seats. The car doesn't even have ABS.
It seems like my problem only happens when it's cold and maybe once or twice when the temperature is over 80F.
I will stick the key in and turn it. I will get the crank but it wont fire. I have to stop cranking and start cranking again 2-7 times before it finally fires up.
The starter always engages.
I have tried a lot of things so far. I have replaced the idle air control valve, battery, alternator, and cleaned up the wires as best I could. I even did the BIG 3 upgrade to see if that would help. It didn't.
I have a second problem and that is once the car starts the dome light inside will flicker. Not on and off but like the voltage isn't correct. It's more like a pulse than a flicker but you understand I'm sure.
Also the voltage when I am running is 13.9-14.2 and when the car is off it's at 12.3-12.7
These are the main issues with my Focus and it's been driving me mad for 2 years now.
I have read a few things about the voltage regulator going out in some alternators but since this one is new-ish and I've had it tested that shouldn't be the issue.
I also wanted to mention that the positive and negative battery cable housings are starting to melt around the wire and exposing it. I can see about 2" of the wire exposed and it is a greenish white color (corrosion) and I am installing a new positive cable today so I will update when that gets in.
Any information is appreciated.
