1 - 5 of 5 Posts
For some reason it only happens after I have been driving for a while. I am pretty sure it's coming from the front end, so I went about checking the front end area. I tried checking both tires, I visually inspected the brakes, cv boots, tie rod ends, control arm bushings, sway bar bushings, sway bar ends, struts, springs. I checked the various nuts on the suspension parts, and all were tight, nothing was loose.
I have 126K miles on the car, I replaced all 4 struts at 100k miles, all fluids are full.
Here is a video with the sound, please ignore the camera work.
http://www.youtube.com/watch?v=XtS1jcTq6Hw
check the sway bar links. if you twist them with your hand and feels rough, replace them they are cheap
Vince your Moderator
^this.
When was the last time you replaced them?
They don't last long IIRC.
The grease-able Moogs are your best bet.
Da fofo love remains
The Moogs are the only thing that has lasted on mine. Busted boots on the Fords, Autozones, and Advanced. Moogs @ Orielys are under $20/per piece.
I was about to order a set for 39 shipped.
1 - 5 of 5 Posts
