1 - 2 of 2 Posts
I just finished installing H&R Coilovers in my '06 ZX3. Everything looks good, but now there's a new noise from the frontend. When sitting still and turning the steering wheel from lock to lock, there is a popping noise from the front end. It resonates so I believe it has to do with the spring.
When I put the coilovers together I had a bit of trouble with the spring seat, bushing and camber plates staying together. The spring seat kept moving off to the side of the bushing. As I put more tension on the spring the seat started to stay in place. It almost seems like the top of the spring isn't wound flat enough to sit on the seat properly.
Does anyone have any idea what this could be? Thanks!
-Brian
Discussion Starter · #2 ·
Problem fixed. I had a bad camber kit that was [:)][:)][:)][:)][:)]ed up.
1 - 2 of 2 Posts
