1 - 12 of 12 Posts
some times when i get in my car, it kinda goes VROOOM vroom VROOOOM vrooom, over and over, and if i give it a lil gas it will come back down and idle at 1.5-2 which, isnt normal..
if i turn the car off, some times that fixes it, some times it doesnt, some times it gets a lot better some times it gets a lot worse...
any one know whats going on?
Discussion Starter · #4 ·
well it did it this morning, when it was cold... but it also has done it at 230 in the afternoon when its warm... so yes and no lol
it could be your tps or you could need to adjust the idle. also it could be sparkplugs or wires. could even be ur clutch/throw=out bearing
Does warm (230 in the the afternoon, mean the engine is warmer, as in the engine is above 240 degrees) or something else
AKA Toyotech
probably a clogged iac. it dop 250-300 rpm here and there?
Discussion Starter · #8 ·
dont know what a tps is, dont need to adjust the idle cause its only doing this some times.. dont know what an iac is and dont know what you mean by dop 250-300
AKA Toyotech
tps, throttle position sensor...which it isn't, and you can't adjust the idle successfully. the iac stands for idle air control, and i mean the drop in rpm
Discussion Starter · #10 ·
not, its just when i turn it on, and it goes from 1-1.5ish with out any help from me, and it just goes up and down and up and down... hehe..
i think its possibly fuel injectors.. bought some cleaner, will see if that helps.
My car does that too when its cold out. But after the car warms up its fine. I have a race header and no cat. That might be why. I just give it a few revs after starting it to get the engine up and running. I just put on a set of ford racing spark plug wires and a set of autolite double platinums and it help on the idleing problem. It is now more responsive as well.
Maybe the cable came off the bracket on the throttle body...I had that happend to me did the same thing. But i just put in an intake must have bumped it in the process.
1 - 12 of 12 Posts
