[:0] I have just bought a s/h 2009 zetec hatchback. and only the centre high level brake lights work! both bulbs and fuse are working.
I researched the net and found this answer......
"I have diagnosed 12 of them and all but one had the same issue. Internal switching failure of the multifunction switch (turn signal switch assembly) on the steering column. This assembly is plastic and fragile The brake signal splits to one wire directly feeding the third brake and the other goes through this switch to be interrupted for rear turn indicators.. The one hold out was actually both bulbs."
Has anyone experience of this?
