1 - 11 of 11 Posts
helo
anyone have stock map voltage value?
i will make a MAP sensor voltage eliminator ....
thanks
the focus has no MAP... MAF yes.
This goes with what i've learned on the forums for some time.
I do believe I am right, But I won't take any shame if someone proves me wrong.
slightly different motor... still technically a duratec, just a tiny list of similarities, and differences.
DIS pack seems to be different... the air-intake is definately different.
the block and head are still aluminum alloy. which is great for weight savings.
Discussion Starter · #7 ·
yes,you are so professional.
DIS and air-intake are different .
so i need some spec to design a MAP eliminate circuit .
i will confirm High voltage to design some components.
I'm curious, why are you trying to remove the map?
Discussion Starter · #9 ·
Helo
i am not remove, i make it eliminated,like a cheater
when NA map detect positive boost pressure, the MAP voltage make high voltage value.
so,i make a circuit to limit high map voltage ...
There are some people who have tried to tune like that in the past, it always turns out for the worst and ends in a destroyed motor.
1 - 11 of 11 Posts
