What is the stock exhuast size? is the MBRP exhuast larger then stock?
thanks for any info,
Shawn Bailey
Shawn Bailey
Thanks for the heads up. Could I not simply drill the hole myself if this is the case with the exhaust they send me?czechers7308 said:there was a fitment issue on my 05 zx3. The front most flange on the cat back has a pin that fits into the straight pipe and alligns it perfectly. The wonderfulk people at mbrp did not make a hole on their new flange to fit into the pin on the car. I had to grind off the pin, and that is not a good idea, because the pin insures 100% alignment between flanges.
What year do you drive and what did you have to mod?Texas Notorious said:Might have to mod it a bit, I had to.
