1 - 12 of 12 Posts
SVT Caliper
Bore:54mm
Bleeder: 8x1.25mm
Port: 3/8-24
Pad: 10x.09700
Loc: Front
Post: Trailing
Caliper Non-SVt
Bore:54mm
Bleeder: 8x1.25mm
Port: 10X1mm
Pad: 10x.08160
Loc: Front
Post: Trailing
Because of more brake pad?
w/ my magic bag
Is there any difference between the SVT Front Calipers and the other models? big and better?
The pistons are bigger for the svt's vs the '05+ ones & of course on the '00='04 ones.....There are other options out also. What spindles are you starting out with?
Trying to identify the spindle/knuckle currently have AP racing brake setup and want to change based on racing class.
Thats What She Said
The knuckles is completely different from SVT to '00-'04 to '05 to '06-'11.
The dog ears for where and how the caliper mounts is different from SVT and '00-'04.
SVT and '05 are the same Caliper mount point but with different ball joint size ('05 is larger)
'06-'11 is the same ball joint at the 05' and same caliper mount I believe but has a larger strut mount.
There are other threads that go into more depth I think.
Discussion Starter #9
Are the non-svt 2000-04 the same knuckle?
Thats What She Said
Any '00 to '04 that was a NON-SVT used the same knuckle across all trim levels (minus SVT). IIRC.
The '02-'04 SVT is a different Knuckle than any other Foci from '00-'11.
w/ my magic bag
Using svt calipers or any bbk= you have svt spindles more then likely..........
1 - 12 of 12 Posts
