What's up Tim?!
New rig! Cool!
SVT suspension wouldn't be allowed in stock class anyway.
Well, you could use the dampers, but not the springs or rear sway,
but that's a moot point anyway.
Won't fit.
The only things you
can change in the stock class is dampers, and the front sway bar.
2006 rules:
http://www.scca.com/_FileLibrary/File/2006_solo_rules.pdf
I highly recommend the KYB AGX (adjustable) dampers, but I'm not sure if they're out for that year yet.
On top of the dampers, get a good alignment.
Front toe: .10-.15 total toe out.
Rear toe: 0 total toe out.
Camber, unfortunately, is not adjustable.
Forget about swapping the front bar, unless you just completely
remove it.
A larger front bar will only increase the inherent understeer, and you can't touch the rear.
What are your plans for tires??
