Well,
A few months ago my 2000 zx3 was having problems keeping temp on the highway at speeds above 70mph. So...
I replaced the entire cooling system.
It seemed to work well for a while but would still operate hotter than normal while cruising at highway speeds.
Today on an extended highway trip while cruising at 70mph for around an hour, the dummy temperature gauge begins to move towards the red. Upon slowing to 60mph, the dummy gauge returns to its normal position (a hair to the left of center)
Considering the entire cooling system is brand new, there are two things I can think of that might be causing this but both of them don't seem to fit.
1. The engine is running lean. My reasoning? I get 35-37 mpg on the highway and the car is rated at 33mpg. A lean running engine will run hot. However, I figured I would get a code thrown at me if the engine was running lean. I haven't gotten any codes.
2. Perhaps somewhere in the hoses of the coolant system, there is a partial blockage and causing the coolant to become too hot to sufficiently cool the cylinders.
Fellow FF'ers, I have posted about this problem before and am at my wit's end. I am pretty well knowledged in this area because I have researched it extensively to try and figure out the problem and still am unable to enjoy my otherwise PERFECTLY running Ford Focus. If anyone can correctly help me diagnose and fix this problem, I am liable to send you some sort of gift basket.
If you would like to talk to me about this over the phone, shoot me an e-mail at [email protected] and I will give you my number. Yes, this problem has brought me to desperation. I will give it one last shot to fix my problem.
PS - If anyone says "check the fans" or "thermostat" I will find you and replace your engine with an SPI engine so help me god.[gunfire]
