1 - 18 of 18 Posts
Ok so i don't know if this will last long here but maybe...
So here is the problem, I have a Kenwood HU and i want to hook it up in my room. The only thing i don't know is the power supply. I don't want a car battery sitting in my room so is there any other way. I know it has to be possible so if anybody can help it would be great.
Well i like the looks and functionality of car stereos better. Also they are much less expensive and it's unique. I just think it would be really cool.
Flat Black King
hmmm im not really sure about this. i know u could just hook the power wire to some power to make it turn on and then wire the speaker wires to whatever speakers u have. just not sure about this one
just simply get an AC adapter with a 12v/1amp output. radioshack comes to mind. take the cord from the adapter and there is your 12v positive/switch and negative. voila
i have one sitting right here for my predator.
you will need to cut the end off the cord of course to get to the bare wires for the HU harness
ok so it will plug into my wall outlet and then i just cut the cord and wire it together?
now if you plan on running subs for some wierd reason, you will need an adaptor with a higher amp rating. but you need to keep it at 12v
i would try to use a 2.5a gives a little more power to the speakers. a 1a converter probably will give you like 5 watts to speakers
Discussion Starter #14
Well i read somewhere that it said to get a 12v 10a power supply. Is that a little overkill?
the radio will only pull as much amps as it wants a 10A would be a little overkill but would not damage the radio
I wouldnt use a standard 12v adapter. Not big enough wire to support the internal amplifier.
I would find a small AC to 12v DC power adapter. Something with a box on the end.
Edit. I didnt see your link up there, yeah it would work fine. 10 amp should be enough.
that is perfect.
1 - 18 of 18 Posts
