1 - 6 of 6 Posts
Has anyone else experienced this? When playing music off my USB (6 spkr radio w SYNC) if I turn the volume above 15, I notice that the track appears to clip. It's not THAT noticeable but I can pick it up. Anyone else? It's not the track itself because it plays fine on other radios.
Rubber Side Down
I dont have a usb port. I know for the cd theres a cd compression setting which works wonderfully. Maybe theres one for usb as well.
Posted via FF Mobile
Above 18 there's a significant db drop in the low and highs, just leaving mids. Makes me FURIOUS when you want to jam!
Does it sound like popping?
I listen to podcasts, and I get a lot of popping / static noise. Only happens every now and then. The dealer told me to get another ipod cable, but that didn't help.
Discussion Starter · #6 ·
Thanks for the comments; there's no popping but it's as if the volume drops for a split second then back to normal, and repeats. But I have noticed if you try to jam with higher volume then lows get cut off, very annoying.
1 - 6 of 6 Posts
