A 7/32" socket will work in place of the 5.5mm socket, and a 15/16" socket will work in place of the 24mm socket. Also, in my experience, remove the radio and cruise control plug first, as it is much easier to remove than the air bag plug. Finally, when reinstalling the air bag, do not over-tighten the 5.5mm (7/32") bolts, otherwise, when you reconnect the negative battery terminal, the horn will wake you up...fast! I tighten them a couple of turns, reconnect the battery, then finish tightening them.
