1 - 12 of 12 Posts
Just bought a momo steering wheel and a hub, are there any discussion on removing the factory steering? or can somebody tell me how to do it by myself.
Thanks [???:)]
its so big and bulky..plus it has the airbag inside of it...so i dont think so.....i could be wrong....
its very easy.. if you can by chance.. swing bye pep boys and pick up the ford focus manuel.. tells you everything in a step by step with pictures.. that will help out alot.
not sure on the focus, but you'll probably need a steering wheel puller. you can find them at most auto stores. on most cars there are 2 bolts behind the steering wheel, take those out and the cover will come off. then use the steering wheel puller to take the bolt out to the steering wheel axle.....pretty easy.
DISCONNECT THE BATTERY BEFORE DOING IT, airbag to the face can break your nose.
Discussion Starter · #5 ·
yep, finished.
unplug the battery for a while, unscrew the two bolt(5.5mm), then easily pull the airbag out
simple and easy.
remember to unplug the battery first!!!
Discussion Starter · #7 ·
ya, thanks man.
but there is no need of special tool for taking the wheel off. a simple wrench will do the job.
[thumb]
This goes along here pretty well. I just want to replace my stock wheel with a leather wrapped wheel in my '03 Sedan. Will I be able to put the airbag right back into the new steering wheel after I remove it from the old one or will I need to do something else first?
Yes, i have done this on my '05, just pop off the old one and put the new one on, replace the airbag. Very easy I did the whole thing in ~10 minutes.
Leather is such a nice upgrade, especially for the steering wheel.
There was a leather SVTF on eBay a few days ago for sale. I think it went for $30.00 shipped an easy nice upgrade. That's the next one I'm doing.
1 - 12 of 12 Posts
