1 - 12 of 12 Posts
previous owner said he changed these a year and a half ago... doubt it
he also said the timing belt was done 38000 miles ago... once again i bet its original with 85000 miles... i did the timing belt and it runs great i bought the gates kit... comes with everything
and i think i found out what the clunking in my front end was i'll have to wait till i go to the wrecking yard and get another one to replace it but this is my passenger side cv axle carrier bearing
I don't immediately see what's wrong with the carrier bearing. Lots of scoring?
I never assume what the previous owner said was done is true. I always do a full tune up and replace all the fluids no matter what. Just cheap insurance and peace of mind.
FF's Night Security
You can buy a new carrier bearing and have it pressed onto the axle, or buy a whole new axle and it will have it on there. Sounds like the car had a rough life before you got it. Good to know it's in better hands that's for sure.
The axles were replaced in december last year so I think they're OK and I saw a bracket at the wrecking yard today before I realised mine was toast and they look the same so I'll at least try it and if its a $10 fix I'm happy with that... but ya I don't believe previous owners either my last focus the guy told me the timing belt was done and it went but I was lucky it was a zx3 and non interference and my motor was OK... since then though I check everything... he had reciepta for the axle replacement which were done at a shop so I believe that... the timing belt was so bad though when I was turning it by hand to find tdc I could hear it creaking and cracking
Discussion Starter #8
The groove shouldn't be there at all I believe its supposed to be smooth all the way across... I'll find out when I get another one
C2H5OH
The lip (it isn't a groove) belongs there. It keeps the bearing in place and the dummy shaft in the trans.
Yes the mount is the same for all MTX/SVT cars (maybe for auto's too but I can't confirm that).
FF's Night Security
^^Good to know. Mine was worn out completely but I just bought a whole axle w/ a new bearing on it. Nice to have a quiet car. It's amazing at how much noise that thing was making. I suspect that this is culprit for some of the other noises focus owner hear sometimes?
That bracket is like 50 from ford, just the bolts and the other part that goes to that bracket is like 13 from ford also, I did mine like 3 weeks ago
Discussion Starter #12
I went and got one from a wrecking yard today and it was different... it would've pushed my axle out 3/4 of an inch further from my block so I'll be getting one from ford... I'm glad they're only 50... and mine had quite a groove worn into it... the picture doesn't do justice but I found it because my axle had about an 1/8 inch of play around the bearing and just spun the whole bearing assembly.
1 - 12 of 12 Posts
