1 - 7 of 7 Posts
Stalls, loud pinging at all speeds, loss of power, PO302, PO303, PO304
My car was running perfectly today. I had excellent power. I then turned off the motor for a few minutes, and when I went to restart it, I heard this aweful pinging noise from my motor and it was tough to start my car and keep it running.
After turning my car over for 20 seconds, it finally starts, but then I still have a loss of power, and a continuous loud pinging noise at all speeds, and if I let it idle it will stall.
Sometimes it sounds real bad.
Does anyone have any clues on what I should check?
Over the past few months, about once a week when I went to start my car, it would run rough for the first few minutes and then the problem would go away.
It is almost as if two of my cylinders are not working.
When I checked the codes, it reported misfires on three cylinders: PO302, PO303, PO304.
When I checked one of the plugs that was misfiring, it was totally wet with gasoline. This was after driving 10 minutes to get home.
try running a compression check if you have a guage - that might clue you in if there is a problem in one of your cylinders.
I think a compression problem would be apparent all the time. He's having intermittent issues. Perhaps your coil packs are going bad. Or you have a frayed or corroded wire.
coolant leaking after I removed the coil
When I pulled off the coil, I found coolant leaking from the ECT sensor.
Replaced the coil, spark plugs, and wires.
The noises and problem still persists.
It almost sounds like the motor isn't getting any oil, but I have oil.
I'm going to let it sit for a few days, try to start it again, if the problem is still there I'll tow it to a dealer and have them look at it.
1 - 7 of 7 Posts
