1 - 10 of 10 Posts
The description of the Comp Cams XR Series Camshafts are a bit confusing to me. I want to get a set of Stage 2s and don't know what to expect.
The "Stage 1" say Mild-rough to Rough Idle
The "Stage 2" Say Rough to Very-rough Idle.
How rough is very rough? Would raising my Idle to say 1000 RPMs smooth it out?
Shot me 3 deer!!!
ya, raising the idle will help. What are the specs on the Comp 2 cams?
Off the CFM Website...
RPM Operating Range: 1800-7000
Duration: Advertised: In: 281 Ex: 281
Duration:mad:.050": In: 228 Ex: 228
Valve Lift: In: .381" Ex: .381"
Centerline: In: 112deg Ex: 112 deg
Shot me 3 deer!!!
ur idle will be just fine w/ the stage II's!! i think there was some good info on them a while back!!
Discussion Starter · #6 ·
Thanks!
I have had my Comp Stage II in for about 2 months now, and I have stalled out about 5 times. I have a CFM tb, and I have a SCT tuner, but I have been too lazy to bump up the idle as yet. Has not been a big problem for me, but I wanted to let you know it does happen.
Discussion Starter · #8 ·
Thanks all for info!
FF Affiliate
I would also look into a wide band AF gauge and a good tune (I can help you there) changing to the bigger cams you need to adjust a few things
Discussion Starter · #10 ·
Tom, how much for a tune? I already have a SCT X-cal2.
Also, what is involved with getting a Wide band AF gauge? Where does it go?
1 - 10 of 10 Posts
