Ok. So I followed the "How-To" to the letter in installing my new ST170 headlights. Here are the problems that I have, and I need your help to solve it.
As some background I went ahead and hard-wired everything instead of "sticking" the wires inside of the plugs.
The Passenger side running light is where I think that the problem is. The wire does not carry any current when I put a voltage tester to it. Also, Neither of the original ground for the side markers are in use currently. So in order to get the drivers side driving light working I piggy backed it off of the current from the passengers side running light.
Here are a list of the symptoms.
(When Headlights are on)
Passenger Side Headlight...Everything perfect; Functioning Properly.
Passenger Side Marker..Working Perfectly
Passenger Brake light... Running light does not come on, but brake light functions properly.
Driver Side Brake Light... Everything Perfect
Driver Side Marker...Out does not function
Driver Side Headlight Functions Properly.
(When Driver's Side Turn Signal is on)
Everything is ok except...
Driver side marker will not operate
Passenger Side rear brake light flashes like turn signal.
Also, the "blinker" sound is operating at double speed since I've done the swap. Please help!
